FlagEmbedding
Model List | FAQ | Usage | Evaluation | Train | Contact | Citation | License
FlagEmbedding can map any text to a low-dimensional dense vector which can be used for tasks like retrieval, classification, clustering, or semantic search. And it also can be used in vector databases for LLMs.
************* 🌟Updates🌟 *************
- 10/12/2023: Release LLM-Embedder, a unified embedding model to support diverse retrieval augmentation needs for LLMs. Paper :fire:
- 09/15/2023: The technical report of BGE has been released
- 09/15/2023: The masive training data of BGE has been released
- 09/12/2023: New models:
- New reranker model: release cross-encoder models
BAAI/bge-reranker-base
andBAAI/bge-reranker-large
, which are more powerful than embedding model. We recommend to use/fine-tune them to re-rank top-k documents returned by embedding models. - update embedding model: release
bge-*-v1.5
embedding model to alleviate the issue of the similarity distribution, and enhance its retrieval ability without instruction.
More
- 09/07/2023: Update fine-tune code: Add script to mine hard negatives and support adding instruction during fine-tuning.
- 08/09/2023: BGE Models are integrated into Langchain, you can use it like this; C-MTEB leaderboard is available.
- 08/05/2023: Release base-scale and small-scale models, best performance among the models of the same size 🤗
- 08/02/2023: Release
bge-large-*
(short for BAAI General Embedding) Models, rank 1st on MTEB and C-MTEB benchmark! :tada: :tada: - 08/01/2023: We release the Chinese Massive Text Embedding Benchmark (C-MTEB), consisting of 31 test dataset.
Model List
bge
is short for BAAI general embedding
Model | Language | Description | query instruction for retrieval [1] | |
BAAI/llm-embedder | English | Inference Fine-tune | a unified embedding model to support diverse retrieval augmentation needs for LLMs | See README |
BAAI/bge-reranker-large | Chinese and English | Inference Fine-tune | a cross-encoder model which is more accurate but less efficient [2] | |
BAAI/bge-reranker-base | Chinese and English | Inference Fine-tune | a cross-encoder model which is more accurate but less efficient [2] | |
BAAI/bge-large-en-v1.5 | English | Inference Fine-tune | version 1.5 with more reasonable similarity distribution | Represent this sentence for searching relevant passages: |
BAAI/bge-base-en-v1.5 | English | Inference Fine-tune | version 1.5 with more reasonable similarity distribution | Represent this sentence for searching relevant passages: |
BAAI/bge-small-en-v1.5 | English | Inference Fine-tune | version 1.5 with more reasonable similarity distribution | Represent this sentence for searching relevant passages: |
BAAI/bge-large-zh-v1.5 | Chinese | Inference Fine-tune | version 1.5 with more reasonable similarity distribution | 为这个句子生成表示以用于检索相关文章: |
BAAI/bge-base-zh-v1.5 | Chinese | Inference Fine-tune | version 1.5 with more reasonable similarity distribution | 为这个句子生成表示以用于检索相关文章: |
BAAI/bge-small-zh-v1.5 | Chinese | Inference Fine-tune | version 1.5 with more reasonable similarity distribution | 为这个句子生成表示以用于检索相关文章: |
BAAI/bge-large-en | English | Inference Fine-tune | :trophy: rank 1st in MTEB leaderboard | Represent this sentence for searching relevant passages: |
BAAI/bge-base-en | English | Inference Fine-tune | a base-scale model but with similar ability to bge-large-en |
BAAI/bge-small-en | English | Inference Fine-tune | a small-scale model but with competitive performance | Represent this sentence for searching relevant passages: |
BAAI/bge-large-zh | Chinese | Inference Fine-tune | :trophy: rank 1st in C-MTEB benchmark | 为这个句子生成表示以用于检索相关文章: |
BAAI/bge-base-zh | Chinese | Inference Fine-tune | a base-scale model but with similar ability to bge-large-zh |
BAAI/bge-small-zh | Chinese | Inference Fine-tune | a small-scale model but with competitive performance | 为这个句子生成表示以用于检索相关文章: |
Frequently asked questions
- Mine hard negatives following this example, which can improve the retrieval performance.
- If you pre-train bge on your data, the pre-trained model cannot be directly used to calculate similarity, and it must be fine-tuned with contrastive learning before computing similarity.
- If the accuracy of the fine-tuned model is still not high, it is recommended to use/fine-tune the cross-encoder model (bge-reranker) to re-rank top-k results. Hard negatives also are needed to fine-tune reranker.
For the bge-*-v1.5
, we improve its retrieval ability when not using instruction.
No instruction only has a slight degradation in retrieval performance compared with using instruction.
So you can generate embedding without instruction in all cases for convenience.
Usage
Usage for Embedding Model
Here are some examples for using bge
models with
FlagEmbedding, Sentence-Transformers, Langchain, or Huggingface Transformers.
Using FlagEmbedding
pip install -U FlagEmbedding
print(similarity)
For the value of the argument query_instruction_for_retrieval
, see Model List.
By default, FlagModel will use all available GPUs when encoding. Please set os.environ["CUDA_VISIBLE_DEVICES"]
to select specific GPUs.
You also can set os.environ["CUDA_VISIBLE_DEVICES"]=""
to make all GPUs unavailable.
Using Sentence-Transformers
You can also use the bge
models with sentence-transformers:
print(similarity)
Using Langchain
You can use bge
in langchain like this:
model_name=model_name,
model_kwargs=model_kwargs,
encode_kwargs=encode_kwargs,
import torch
model.eval()
# Tokenize sentences
# Compute token embeddings
with torch.no_grad():
# normalize embeddings
Usage for Reranker
Using FlagEmbedding
print(score)
print(scores)
import torch
model.eval()
print(scores)
Evaluation
baai-general-embedding
models achieve state-of-the-art performance on both MTEB and C-MTEB leaderboard!
For more details and evaluation tools see our scripts.
- MTEB:
Model Name | Dimension | Sequence Length | Average (56) | Retrieval (15) | Clustering (11) | Pair Classification (3) | Reranking (4) | STS (10) | Summarization (1) | Classification (12) |
BAAI/bge-large-en-v1.5 | 1024 | 512 | 64.23 | 54.29 | 46.08 | 87.12 | 60.03 | 83.11 | 31.61 | 75.97 |
BAAI/bge-base-en-v1.5 | 768 | 512 | 63.55 | 53.25 | 45.77 | 86.55 | 58.86 | 82.4 | 31.07 | 75.53 |
BAAI/bge-small-en-v1.5 | 384 | 512 | 62.17 | 51.68 | 43.82 | 84.92 | 58.36 | 81.59 | 30.12 | 74.14 |
bge-large-en | 1024 | 512 | 63.98 | 53.9 | 46.98 | 85.8 | 59.48 | 81.56 | 32.06 | 76.21 |
bge-base-en | 768 | 512 | 63.36 | 53.0 | 46.32 | 85.86 | 58.7 | 81.84 | 29.27 | 75.27 |
gte-large | 1024 | 512 | 63.13 | 52.22 | 46.84 | 85.00 | 59.13 | 83.35 | 31.66 | 73.33 |
gte-base | 768 | 512 | 62.39 | 51.14 | 46.2 | 84.57 | 58.61 | 82.3 | 31.17 | 73.01 |
e5-large-v2 | 1024 | 512 | 62.25 | 50.56 | 44.49 | 86.03 | 56.61 | 82.05 | 30.19 | 75.24 |
bge-small-en | 384 | 512 | 62.11 | 51.82 | 44.31 | 83.78 | 57.97 | 80.72 | 30.53 | 74.37 |
instructor-xl | 768 | 512 | 61.79 | 49.26 | 44.74 | 86.62 | 57.29 | 83.06 | 32.32 | 61.79 |
e5-base-v2 | 768 | 512 | 61.5 | 50.29 | 43.80 | 85.73 | 55.91 | 81.05 | 30.28 | 73.84 |
gte-small | 384 | 512 | 61.36 | 49.46 | 44.89 | 83.54 | 57.7 | 82.07 | 30.42 | 72.31 |
text-embedding-ada-002 | 1536 | 8192 | 60.99 | 49.25 | 45.9 | 84.89 | 56.32 | 80.97 | 30.8 | 70.93 |
e5-small-v2 | 384 | 512 | 59.93 | 49.04 | 39.92 | 84.67 | 54.32 | 80.39 | 31.16 | 72.94 |
sentence-t5-xxl | 768 | 512 | 59.51 | 42.24 | 43.72 | 85.06 | 56.42 | 82.63 | 30.08 | 73.42 |
all-mpnet-base-v2 | 768 | 514 | 57.78 | 43.81 | 43.69 | 83.04 | 59.36 | 80.28 | 27.49 | 65.07 |
sgpt-bloom-7b1-msmarco | 4096 | 2048 | 57.59 | 48.22 | 38.93 | 81.9 | 55.65 | 77.74 | 33.6 | 66.19 |
- C-MTEB:
Model | Embedding dimension | Avg | Retrieval | STS | PairClassification | Classification | Reranking | Clustering |
BAAI/bge-large-zh-v1.5 | 1024 | 64.53 | 70.46 | 56.25 | 81.6 | 69.13 | 65.84 | 48.99 |
BAAI/bge-base-zh-v1.5 | 768 | 63.13 | 69.49 | 53.72 | 79.75 | 68.07 | 65.39 | 47.53 |
BAAI/bge-small-zh-v1.5 | 512 | 57.82 | 61.77 | 49.11 | 70.41 | 63.96 | 60.92 | 44.18 |
BAAI/bge-large-zh | 1024 | 64.20 | 71.53 | 54.98 | 78.94 | 68.32 | 65.11 | 48.39 |
bge-large-zh-noinstruct | 1024 | 63.53 | 70.55 | 53 | 76.77 | 68.58 | 64.91 | 50.01 |
BAAI/bge-base-zh | 768 | 62.96 | 69.53 | 54.12 | 77.5 | 67.07 | 64.91 | 47.63 |
multilingual-e5-large | 1024 | 58.79 | 63.66 | 48.44 | 69.89 | 67.34 | 56.00 | 48.23 |
BAAI/bge-small-zh | 512 | 58.27 | 63.07 | 49.45 | 70.35 | 63.64 | 61.48 | 45.09 |
m3e-base | 768 | 57.10 | 56.91 | 50.47 | 63.99 | 67.52 | 59.34 | 47.68 |
m3e-large | 1024 | 57.05 | 54.75 | 50.42 | 64.3 | 68.2 | 59.66 | 48.88 |
multilingual-e5-base | 768 | 55.48 | 61.63 | 46.49 | 67.07 | 65.35 | 54.35 | 40.68 |
multilingual-e5-small | 384 | 55.38 | 59.95 | 45.27 | 66.45 | 65.85 | 53.86 | 45.26 |
text-embedding-ada-002(OpenAI) | 1536 | 53.02 | 52.0 | 43.35 | 69.56 | 64.31 | 54.28 | 45.68 |
luotuo | 1024 | 49.37 | 44.4 | 42.78 | 66.62 | 61 | 49.25 | 44.39 |
text2vec-base | 768 | 47.63 | 38.79 | 43.41 | 67.41 | 62.19 | 49.45 | 37.66 |
text2vec-large | 1024 | 47.36 | 41.94 | 44.97 | 70.86 | 60.66 | 49.16 | 30.02 |
- Reranking: See C_MTEB for evaluation script.
Model | T2Reranking | T2RerankingZh2En* | T2RerankingEn2Zh* | MMarcoReranking | CMedQAv1 | CMedQAv2 | Avg |
text2vec-base-multilingual | 64.66 | 62.94 | 62.51 | 14.37 | 48.46 | 48.6 | 50.26 |
multilingual-e5-small | 65.62 | 60.94 | 56.41 | 29.91 | 67.26 | 66.54 | 57.78 |
multilingual-e5-large | 64.55 | 61.61 | 54.28 | 28.6 | 67.42 | 67.92 | 57.4 |
multilingual-e5-base | 64.21 | 62.13 | 54.68 | 29.5 | 66.23 | 66.98 | 57.29 |
m3e-base | 66.03 | 62.74 | 56.07 | 17.51 | 77.05 | 76.76 | 59.36 |
m3e-large | 66.13 | 62.72 | 56.1 | 16.46 | 77.76 | 78.27 | 59.57 |
bge-base-zh-v1.5 | 66.49 | 63.25 | 57.02 | 29.74 | 80.47 | 84.88 | 63.64 |
bge-large-zh-v1.5 | 65.74 | 63.39 | 57.03 | 28.74 | 83.45 | 85.44 | 63.97 |
BAAI/bge-reranker-base | 67.28 | 63.95 | 60.45 | 35.46 | 81.26 | 84.1 | 65.42 |
BAAI/bge-reranker-large | 67.6 | 64.03 | 61.44 | 37.16 | 82.15 | 84.18 | 66.09 |
Train
BAAI Embedding
BGE Reranker
Contact
If you have any question or suggestion related to this project, feel free to open an issue or pull request. You also can email Shitao Xiao(stxiao@baai.ac.cn) and Zheng Liu(liuzheng@baai.ac.cn).
Citation
@misc{bge_embedding,
year={2023},
eprint={2309.07597},
archivePrefix={arXiv},
primaryClass={cs.CL}
- Downloads last month
- 68,939
